I doubt it.
The big problem was the early airbox warping in the heat. This could cause the ICV to malfunction. The solution was a new design of both.
However, the ICV was and is still in the K13, an open loop system. The ECU sends it, via a set number of pulses to the internal stepper motor, to where it wants it to be, dependent on air and engine temp, air weight etc. etc.
The fly in this particular ointment is that the ECU 'assumes' it knows where the ICV is in its travel, based on where it last sent it to. But, if the ICV did not get to the last 'known' position, the ECU has no idea of this (open loop) and carries on regardless.
Now, the ICV is supposed to reset itself on engine start. Actually, on ignition on. But, it can get stuck, or rather sticky.
TomL had some success by removing the ICV from the base of the airbox, disassembling it (carefully or the spring and piston go whheeeeee), cleaning it and re-installing it. I believe this was for a problem on a K13.
You really need to whip the tank off and take a peek at your ICV. This will tell you if you still have the old design. If you do, you know the solution.
