I did it with minimal stripping down Steve.
Belly-pan off, tank side panels off and tank out, assuming you are swapping the pipes as you need to get to the Oxy sensor plug. You don't need to remove the tank or tank panels if you are just changing e.g. the manifold gaskets.
Once you have gone that far it is straightforward to take off the manifold stud nuts (10mm 12 point or double hex nuts). Clearance behind the fan is interesting and next time I will take the fan off the back of the rad first as it is a great opportunity to clean out the radiator from both sides.
If you intend to take the fan off, the top right hand hex drive screw in the fan is a bugger as it is occluded by the block, but if you take off all the radiator mounting washers and clips and ease it forward, you can just about get the screw out with a pair of snipe-nosed pliers or grips. If you then file flats on the head of the screw, it is easy to get it out with a spaniard next time!
I took the manifold off with the fan in situ as I was in a hurry to beat the darkness last evening. However, with the fan out of the way, it is easier to get inside the recessed exhaust ports to clean the faces up prior to fitting new gaskets, which, if the layers separate like mine did, appear to be handed, but aren't. It would also be easier to get to the manifold nuts with the fan off.
There are loads of exhaust fabricators but their work is horrendously expensive for low volume work. They really need a jig (engine in frame is ideal) and the skill needed to get the head end flanges true and correctly oriented is not negligible. Also, the spherical end of the pipe to which the silencer connects is not a trivial piece of work.
However, having said all of that, if we can get a bunch made up somewhere that has low labour costs, then it might be affordable.
Brian (who thinks his existing headers may be beyond saving, time and Dave the welder will tell)
PS Note my modified statement (underlined above in para 5) about the gaskets.
