« Reply #19 on: January 08, 2022, 02:37:38 pm »
As the first mechanic couldn't find a solution I took the bike to Graham's Motorcycles in Bradford and Stephen found the problem within two hours. It helped that he had the diagnostics from the first mechanic and he eliminated it being a compression problem based on his experience of these bikes and the fact that valve clearances were good. He lifted the tank and shone a light down onto the air intake throttle bodies while the bike was running and noticed that the No 2 boot/seal was perished and leaking causing the bike to run lean and on three cylinders. It was obviously not apparent without the bike running so was probably missed by the first mechanic on that basis. I am replacing all four seals and whole cost will be £457 which is more than reasonable to get the bike back in shape. The only downside is that I was halfway to getting the wife to agree to a newer replacement still it's a great bike so I shouldn't grumble. Sometimes the simplest solutions are right under your nose!
Thanks for sharing the solution I am sure somebody will benefit from it in the future.
Logged
Prevoius bikes:-Ducati Scrambler 800 Urban Enduro, Aprilia Tuono Factory V41100, VFR800 Fi, K1300S, K1300R, YAMAHA MT10 sp, K1300R, K1200R, GSX1300 Hayabusa GEN1, GSXR1000k3, GSXR750Y2K, YAMAHA EXUP RU,NC30-VFR 400, GSXR600WW, XL600R, Z1B, GPZ1100B1, GPZ900R, GS550, Z1B, Z1A, GT380, GT185, FS1E.
