Author Topic: First cylinder spring no 2 broken  (Read 224 times)
Re: First cylinder spring no 2 broken
« Reply #15 on: April 29, 2018, 01:32:19 pm »
I think Poeton in Gloucester do replating of cylinders. Might be worth a try, if you can get the block to them.http://www.poetonaptec.co.uk/cylinder-repair.htm
Still an awful long way from Athens...
« Reply #16 on: April 29, 2018, 02:36:16 pm »
What have you decided to do Costas? You could get by with one piston if the bore isn't scored.
« Reply #17 on: April 29, 2018, 04:17:42 pm »
Methinks that perfectionist Costa (the mechanic) might have some input on that score 😇
Offline vm5
  • My K bike model:: k1300s
  • Modifications and add-ons:: Modified and revalved wp esa shocks
« Reply #18 on: April 30, 2018, 05:19:41 pm »
Here in Italy, on some single cylinder engines I've experienced the renew of nikasil via  galvanic treatment  without issue. There's a factory near Lecco (where there's the Gilardoni factory that already worked fo BMW)that for a 250 cc single cylinder asks about 150 € . I dons' know if they do it for a four cylinder but i think that is possible.
https://www.rammotor.it/lavorazioni/
